Looking for a VOD APK with simple IU with Debrid Integration
I currently have Kodi, Stremio and had Flixvision but I kept reading how Flixvision had some shady stuff running in the background so I uninstalled it on all my devices.
So I’m looking for a replacement for Flixvison that works with multiple Debrid services at a time and works with external players such as Kodi.
Was looking at Weyd & Syncler which I haven’t used in YEARS but now see they charge for it. Are those my best options or is there something else with a simple IU ?
Reason I’m looking for something is for family members that are not very tech savy…lol
Just became a Patron Member after being here for about 4 years now…lol
I’ve been using weyd for about 4 years and love the simplicity and tidyness of the U.I
Simple enough for the wife and fun for me. You can add liked lists from Trakt or Wetrakr to appear in your lists, you have cloud access to all your Debrid files. The lifetime is a great option and you get support and access to early beta releases if you want. Integrates with Orion if you use it.
Just realized Syncler only accepts Bitcoin which I’m not savy with…lol
Check out Wuplayer. A fantastic debrid app​:+1:
The app is free aswell
CinemaHQ fills the bill. Stand alone app. If they aren’t tech-savvy, you don’t want Kodi.
But as CinemaHQ uses Honeygain SDK which…When an app developer integrates the Honeygain SDK into their application, they use your device as a proxy node to route web requests for corporate clients
If you are using Stremio then apps like Wuplay, STRMR, Nuvio, and 100 others will work with your add ons.
As doe Flix Vision, I still have in it installed and it was my main app until I found others.I think you can pay for syncler with a CC through one of the other payment stores. I really like weyd but sine Trakt screwed every one up, I switched to simkl and weyd is not set up to add it. so I doubt I will be renewing mine. I did renew my syncler.
You may also want to check out Debrid Stream, it is a paid app also but it is also close to netflix experience with 1 click play on most streams. I think it is $20 a year.
I’m doing a free trial of Weyd and it’s got a pretty simple UI which is what I’m looking for . I haven’t use TRAKT for many years and don’t care to use it.
Would like to compare it to Syncler but I don’t care to use crypto
There are options.
Yes, but you can turn it off in settings.
Thanks
I use Weyd and the software puts.a check mark on watched episodes. You can even mark or unmark entire seasons, so Trakt not necessary for me. Only disadvantage is that you can’t login on another device and pick up where you left off. Otherwise it’s a straight forward easy to use app
Hello, I would strongly suggest looking at Nuvio. Here is video I just put up for it.
How do you turn off in settings?
Honey gain SDK
Yes try Debridstream, I have been a Syncler user since the TV Zion days and really love the app but for someone who is fairly new to this Debridstream is easy to setup, simkl integration and very easy UI, very Netflix like. I like the ability to skip the intro and get right to the show.
I couldn’t find “Honey gain SDK” but I turned off sharing, not sure if that is the same. Anyone know for sure? Thanks
You may also want to look into Plex for free legal live IPTV and VOD.
I’ve been using DebridStream App (which I found on TroyPoint). It costs about $25 per year, but the simplicity of it is great. It has a Netflix type interface and very simple to set up. I pair it with Premiumize and been using it for a couple of months now. Very easy to set up and, like you, wanted to have something that non-tech savvy family members (or friends) can use. Very happy with it.
