Looking for a mobile phone friendly IPTV player with Tivimate type features
I have a z fold 7 and a few IPTV services. I would love the ability to use them all at the same time ie. search across all of them like Tivimate. Easily navigate the playlists to find content. Folder customization would be a huge bonus. But again must be phone friendly. Any suggestions?
Thanks!!
I know how to install it and have, thanks. But the navigation sucks. No two ways about it. It’s not made for touch screen. That’s why I am searching for other options.
Glad you know how to install IPTV on your phone. That’s a good start. Maybe this would be worth looking into
Others in the Troypoint thread have successfully installed this on their phones and you may be able to get their help.
MYTVOnline + is free to upgrade to premium - can use on Android phones / tablets or iphones / ipads
Available to install from Google playstore or Apple app store
Thanks @MikeN that should give @termn8er a couple of options to look at. Hopefully one works for them. Have a great weekend.
wassup n8er..
If you like tivimate better, you can still watch & navigate Tivimate on a phone or tab, you just cant do any editing or last channl stuff due to touch screen, but you can change a couple remote actions to get around easier
to navigate easier i you go into
settings..
remote control..
change ‘hold ok’ button to channl list groups in overlay mode
that way you can get to all yor groups & channls by long touching the screen
then just tap the screen to use the control panel (bottom guide) for quicker channl change
hth..
Smarters Player
I have Smarters and you are required to switch between accounts. I’m looking for something better!!!
Or pair an old firestick remote to your phone.
Please post what you have tried, will help you get better suggestions
Wow Mytvonline is really great for free. You can easily hide unused channels then you can pin a channel to the top and reorder the pinned channels anyway you want. As MikeN said you get a free premium account now. You can easily search across multiple playlists. Thanks MikeN!
I like it as well.
I wonder what features you lose when premium expires?
“Free premium promotional period subject to expire at any time without prior notice. Continue your premium experience after the promotion ends by linking your Formuler device or through in-app purchase”
I have a Z fold 7 and I have Freegotv on my phone. 17000 channels and plays perfectly.
