Log in Superman build
Can someone please tell me where to find the log in the Superman build? I could keep looking all night but everyone is so helpful. Thanks in advance.strong text
Can you be a little bit more clear please. Are you looking for the url or are you on the cman app looking for superman.
I gave up for a bit. Checked my message again today. Thank you, thank you, thank you Troy point. You are the greatest. I installed the add-on and I’m now looking at my log. If not for you I would have given up for a while and just reloaded everything.
Try going on troypoint.com. Search for best builds on KODI …it’s a little involved if first time but that is how I done it …note some times your firestick does not show exactly as shown go back button try again if wrong clicked …download some times it’s going slow but you click and mess it up be patient.
