Locked out of my laptop
I recently reset my laptop after I couldn’t create a restore point. When it booted up to my login screen, I put in my pin as usual only to find out it said incorrect. I’ve tried everything except for geek squad support :grimacing:. Can anyone help me?
Is this a windows PC? If so have you gone to the Microsoft site and tried logging in to your account and choose forgot password? That’s all I got for this
maybe if you can start in safe mode then run system restore might work also you may be able to reinstall windows keeping your files intact that will be in the windows control panel
You must have restored the PC back to before you put in the new password. Yeah looks like a $199 geek squad payment.
or worst solution do a fresh install
What version of windows do you have?
I can’t even do that. F8 not an option.
Windows 11
if you cant get it to boot from win disc or usb ime lost sorry hope someone can help further good luck
Change or reset your PIN - Microsoft Support.
Also see -
A world-class Windows password reset tool to reset Windows Admin and Standard user account password on Windows 11/10/8.1/8/7/XP/Vista without losing data. Besides resetting a password, it is capable of creating a new account via CD/DVD or USB drive.
When You Will Need imyPass Windows Password Reset
A password is required in Windows computer login or making some changes. For one reason or another as below, you may need to reset or remove Windows password. That’s what imyPass Windows Password Reset can assistant you instantly.
  • Lost/Forgot Windows Login password
    Forgot or lost login password and cannot log in to Windows computer.
  • Log out of computer
    Log out of computer and cannot log in without a password on Windows.
  • Forgot Admin password
    Forgot Admin password and cannot make some changes on Windows computer.
  • Want to create a new account without administrator access
    Standard users without administrator access and want to create a new account.
How imyPass Windows Password Reset Works
Without any complicated helpers or settings, imyPass Windows Password Reset offers you 2 ways to reset password on Windows via CD/DVD and USB flash drive. Support Windows computers which are equipped with BIOS or Legacy mode.
  • Create with CD/DVD
    Burn Windows password recovery disk with CD/DVD drive to boot up any locked Windows computer.
  • Create with USB Flash Drive
    Make a bootable USB flash drive from SanDisk, Kingston, Toshiba, Samsung, etc., to reset password.
Support All Windows Types
No matter what version your Windows computer is, this password cracker can remove and reset password easily, and help you create a new standard account conveniently.
Homepage
Code:
https://imypass.apeaksoft.com/
imyPass Windows Password Reset Ultimate 1.0.10 + Patch-RLTS | 128.44 MB
Code:
https://rapidgator.net/file/bac9c22dc398233ef801737e471de4ba/Windows.Password.Reset.Ultimate.v1.0.10.msstdfmt.rar.html
Yep, a linux boot disc can be a great tool when needing to find out a password or reset one…
If your laptop account is Local and not microsoft, this guide will help you.
https://answers.microsoft.com/en-us/windows/forum/all/i-accidently-got-locked-out-in-windows-11-laptop/e4247487-794c-48e6-adfc-5f0189fa2fa2
So that’s how you hack a computer!
Thanks all. Unfortunately Lenovo has it set up so these tips won’t work. I bit the bullet and got a Best buy geek squad appointment. Again many thanks.
Stupid question but if you reset your laptop, did you try to leave the password blank and just hit enter?
I’m sure you tried it but just in case. Just trying an easy solution before you go to the Geeks.
Use another computer to download and register “PCUnlocker”. It creates a bootable USB drive. Once booted, it allows a user to remove any existing passwords. When finished, your laptop will boot normally without the need of a password. Go into Control Panel —> User Management to set up a new password if desired. Registration for the basic version is $20 and the “professional” is $30. Works like a charm!
