New to the forum. Thanks in advance for any help and suggestions. Came across CK Hosting while at my Sister in Law’s house & really like it. Have purchased a one month subscription, received username and password but cannot figure out how to load it onto my fire stick 4.0. My nephew said it took them hours to get it onto her fire stick, and from there is no help. lol Many thanks!
https://troypointinsider.com/t/resetting-your-firetv-os-and-firestick-guides/55887?u=tp-dracoo
Probably should have read of this and went to troypoint.com and read the guides first. Thank you for patron support.
Thanks for the help. I’m new here & have a lot to learn. I only did a general search for CK Hosting & came up with nothing.
Dracoo gave ya the most important piece of the puzzle, TiViMate. Did your IPTV supplier give you the xtream codes or just an m3u8? Either way, get the Tivimate companion app and buy a lifetime sub. Not sure on the price at the moment but It was $25 USD for lifetime. I think I saw it went up to $27.50 but don’t quote me. This app is where you add your subs and get the playlist and EPG loaded.
As suggested by other get Tivimate!
From the way you wrote your post it reads like they sent you an extream code. The pic are instructions for installing an extream code.
What I got from CK Hosting was a username & password that they generated. No m3u or xtream code - or at least nothing that specifically said that is what is was. I saw TiVimate listed on TP’s list of top IPKs so I think I’ll check them out & cancel CK. Many thanks.
You need and MUST have a m3u url or an xtream code to be able to install on your player. Unless your iptv service is forcing you to use their exclusive player. If that is the case, then you will need to download the iptv service’s player. They most likely have their url code embedded in their player and you would only have to insert you UN & PW.
Personally, I won’t use a service that requires me to use their own player, but that is my personal desire.
they probably gave you the username and password for their website. Login and there are probably M3U or xtream code options for your account.
They probably have their own app to use. If so ask your provider who or what player they use? and if possible use Xtream codes and install Tivimate as your player. Welcome, hope this helps.
I’ve actually sent 2 requests (one thru email and the other thru a “service ticket”) asking about the m3u and xtreme code. No response to either one after 3 days so I’m writing them off and going to check out TP suggestions. Thanks much!
Most definitely, Do trials of various one’s till you find the one for you. Customer service is probably a good indicator of their product. Use Xtream code whenever possible, so much easier.
