Live TV kodi & mad titan sports
How do I prevent being kick out of watching live tv or sports program . I’m using Mad Titan Sports & at times it will go for half an hour, at times 5 minutes maybe.
With kodi you should always have a back up addon to your regular. do a search for sports kodi addons and experiment with them, it’s hard to recommend one without knowing which sport you are having trouble with. I have a iptv service but mostly watch sports on kodi because I usually watch sports on my pc .
Are you using a VPN, Promise and Homelander have IPTV as well as mad Titan.
I watch live tv on MT & live sports & they both kick me out after sometimes 5 min sometimes 15 or so. I have used it with my VPN on & off. Also have used real debrid with the same results
I have used a VPN & it does the same with it connected or not.
ok, RD is only for movies and TV series. Live TV has been a bug-a-boo on kodi since ustv went down. Also, I have not seen anyone post that they have found a reliable LiveTV on kodi. Sports on the other hand is very reliable. BUT, i am only talking about MLB and English Soccer. I use the Loop for those and they have been solid. If they work well with my two sports, then they should be good for other sports.
Thanks I’ll give that a try.
For Premier League I use Sport hd, Asgard and Rising tides with the VPN.
Daddylive,MadTitan,and TV_APP among others live feeds no longer working again. Anybody else experiencing this? Solutions?
KODI works great for VOD. Your not going to have sustained success using it for Live TV. These Devs are unpaid. Shi$ breaks all the time on the IPTV in KODI. Get a paid IPTV Service. Search here lots of info.
@Jimbob I been there and done all them options. Like MarkxG said get you a paid iptv. I use a cheap Alibaba subscription for $18 year. It works 95%-98% which suits me fine as a hobbyist. While there are better options out there they will cost $50-$200 year.
Troy has ton of info here so just search and read.
Tv app working for me
