I don’t have an ONN anymore sorry. But once you’ve activated USB debugging in the developer options that’s universal and only needs to be turned off after that, if needed.
Be careful with Wolf Launcher. When I first got my box I put wolf Launcher on and it Bricked the ONN. Happened to several others here as well if you do a search you will find. Luckily was able to restore it. I just set it to Apps mode now
When you open Launcher Manager, what does it say is your current launcher?
Currently when I open Launcher Manager it shows Google TV. If I click enable, then Wolf Launcher can become my primary. Somehow, I got to make Wolf Launcher my alternate. Since I do have the ATV launcher app …wonder if I delete Wolf Launcher from apps…if I then can load ATV on Launch Manager?
thanks for your help.
Currently when I open Launcher Manager it shows Google TV. If I click enable custom launcher then Wolf Launcher can become my primary. Somehow, I got to make Wolf Launcher my alternate. Since I do have the ATV launcher app …wonder if I delete Wolf Launcher from apps…if I then can load ATV on Launch Manager?
As long as Wolf Launcher is not the current launcher, you can safely uninstall it. I recommend that you do that, then reboot your device. Then, you can open Launcher Manager and enable the custom launcher, which should be ATV if you have it installed. Hopefully, that will solve the problem. Best of luck.
I feel your pain. ‘A’ does everything you want it to do and more. but… Beyond your control, the way things are, ‘A’ isn’t able to do much more because ‘A’'s Owners have the code and are eliminating certain functions. So, you try ‘B’. ‘B’ is made cheaply all around…just take a look at the price. So, you are forced to go back and deal with ‘A’. In your case… There may be a solution. Try ‘C’… A Chrome Box.
After reading your post, that is what I’m going to invest money in. I have both a FS & ONN and… I can only do so much with both of them. In fact I do not want my Entertainment System at home to have anything to do with streaming ANYMORE. Starting in April…‘Servers’. Build my Base with these.
