Just noticed that Silk displays a message that downloading is not supported at this time. Sheesh!
It’s not an app. It is a webpage. You can save the page to your favorites.
Also, once you have saved it you can make a shortcut using the TV App Repo so that it appears on apps page on your device.
Thanks but that is not an option on my 4K version of Silk
You are right. I just checked and Silk does not have an APK installer on the sticks. You can download them but then ya have to use say the ES File Explorer to install it. Sorry about that.
Use TVBro. It work great and I just now searched the site, saved it to my favorites, and made a shortcut to appear on my apps page on my Shield Pro.
Thanks. I’ll check it out.
Does anyone know what the latest update fixes or addresses?
Just states “fixes and improvements”. You could join the Tivimate discord thread…TiviMate Community
