The service that I subscribed to uses ky-iptv.com . Today, it seems to have gone non-existent..
I believe that a lot of IPTV services use this?
Does anyone have any info?
I submitted a ticket, and they sent me this:
If you need the new XStreams server codes, these are the 4 that are working
http://ky-tv.cc
http://kytv.xyz
http://ky-tv.cc:25461
http://kytv.xyz:25461
Hope this helps someone..
Thanks! ![]()
Thank you! I have Xtreme HD & had my URL quit working & God bless another patron on here for sending me 3 URL’s to try. The first one here I can confirm does work. 2 he sent me are different from the list you have here so here are the 2 extra ones for you all…
You’ve found that both the urls that you posted are working with your Xtreme login?
I can verify that the ky-tv.cc:25461 is working. I didn’t try the others.
I can confirm the first one I listed here “iptvport.net” does indeed work as I already stated.
Kytv.xyz also works
Thank you! It worked!
Don’t work
Have you tried all the suggestions? Looks like there are about 6 or 7 different ones to try.
I had the same issue with 2 providers that use that url. Fortunately, they gave me backup servers at sign up and I am using those and they work.
The cc ones and xyz works.
Use your VpN for another country it works
Thanks I reached out to them and got no reply at all and they have my paid sub
Thank you!
I can’t get my EPG to update. I used http://ky-tv.cc:25461/ and I have service but no EPG. Any suggestions? TIA
Try one of the other servers. kytv.xyz works fine for me.
How do you Sid it a ticket? Are they gone forever? Mine quit working and my sub has not expired just wondering? Thanks much
Sorry how did you submit a ticket?
