I have been having issues with Kodi 19.3 starting. When I click on Kodi the screen turns grey and it will stay that way for 10-15 minutes. I have tried restarting, rebooting and all the obvious trials. This is apparent on two different firesticks on two different TV. I am using the newer 4K Firestick.
Welcome to our community!
Sounds like you may be using all of your firesticks resources.
Uninstall all unneeded or unused apps.
Clear your cache and data.
Make sure firestick is getting power from wall and not tv
Try to put kodi on a USB
Are you running any builds?
Only using about 40% already dumped all apps except Seren and Oasis so none of the above.
Hi @Technobody
Do you have enough power to the devices? Meaning are they plugged directly into a wall outlet and not through another source.
Yes plugged directly into surge protector same as TV
@Technobody Plug directly into wall outlet as @Sbrowne126 suggested. Sometimes there is a slight power drop when plugged in a surge protector.
