How do I return back to the main Kodi settings page after I install a build? Thx.
Find settings in the build- then click skin- then Estuary
I can’t find skin anywhere in the Crewnique build. Any suggestions? Thx.
Sorry I don’t have it installed, Search on here. Wish I had something else. I know someone here has it installed and can help. I also noticed watching a tutorial on Crewnique that there’s skin settings at the bottom of the page if you scroll left or right. Also in the system tab there should be interface and maybe that will allow you to swap skins.
I found it. Skin is in the system tab. Thanks for your help.
