Been a long time looker in the Troypoint and member. First timer post. Hear my issue. I have the latest update Firestick, and past user of Kodi Build. I decided to update the Kodi from 19.5 to the 20.0. After updating I try to instate the Xenus (diggs) build suggested by the Troypoint page. However it won’t play any movies or tv shows. So I decided to try other builds and it will need “real debris” or it would display a link no matter what build I use.
I’m not sure I understand your issue but if you don’t have Real Debrid that is most likely your issue. I’ve been using Builds for years but not Digg’s as they have tons of problems
Like MarkxG i am not 100% sure of you issue either.
Diggz currently has 3 builds:
A Debrid only version
A Free version
A Free version that requires a VPN
The free versions will not give you as many or possibly any results as the Debrid only build will. Results will also depend on the addon you use to search with.
If you dont have a Derid account then you only have 2 Diggs build to choose.
If you dont have a VPN either then its down to 1 build to choose.
There are also 2 non-Diggz builds available in the Chef Wizard but I never used them so i cant say how they work.
Thank you all for the replies. The Kodi that is installed on the FireStick is the 20.3 and I don’t have Real Debrid. There’s no problem in installing a “Build” weather is Diggs, Superman even the Crew, the videos does not play. It tells me check the error log or no stream. No matter the Movie or even TV shows.
Meaning for some reason I cannot use the Kodi or the Build it would play any videos/movies. Again there’s no problem with installation it’s the play video. Hope that’s more clear.
It’s not that it WON’T work without RD, it’s just that with RD the experience is more rewarding, smoother, easier to use and expands functionality, and all at a very reasonable price.
Playable free sources have pretty much disappeared from KODI. I use KODI daily with Real Debrid. It’s .10c/day. But if you don’t want to pay for RD then you are going to struggle with playable sources in KODI IMO.
