Kodi question about search results
I’ve got a few TV shows saved, but recently did a search under the TV shows that ended up being not what I wanted.
Is there a way to clear individual results?
Are you asking is there a way to clear search history within an Addon? If so that depends on the Addon. They are all different but there should be an easily identifiable “clear search history” or something like that if you can
Like Mark said, it all depends on the addon. What addon are you using?
I’m using Diggz add-on.
I know how to clear the search history, but what I’m asking is if there’s a way to select individual search results. For example, I did a search for a tv show I watched as a kid. I received three results from the name of the show, none of which what I was looking for. I’d like to remove those three results.
Ah, Diggz is a build which, unfortunately, I have no experience with. I assume that you are using an addon within the build. It may be The Crew or Scrubs or something like that.
Most all of my experience is with the Fen/clone addons. I’m just shooting from the hip, but sometime you can long press, within Search and it will bring up a small menu with the option to delete the link that you want to get rid of.
Mark is the guru for builds here. maybe he can step in.
Yes.
Long press the search word(s) and you should be given an option to clear search phrase.
I use Diggz xenon plus and if this doesn’t work tell me the diggz build and addon you are using. I will test.
Edit… you are looking to erase the results? Not sure i understand. The results will be there based on your search criteria.
I use Diggz xenon. I don’t know if it’s the “plus” version or not.
I’ll try doing the long press.
I’ve got 4 search results I want to keep. I’ve got three search results I want to get rid of.
I tried the “long press” and the only options were to add to favorites, super favorites, etc. No option to delete.
Send pics. No one understands what you are talking about.
Are you talking about search results or search criteria?
What are you searching for?
