KODI on an iPad
I have been using Kodi for about a year now on three separate Amazon fire sticks and recently on my Apple MacBook Air.
Now, I want to be able to watch sports events on my new iPad with Crew Sports on Kodi.
Where do I go to download the Kodi app to my iPad?
Here you go. Good luck
https://kodi.wiki/view/HOW-TO:Install_Kodi_for_iOS
:pirate_flag: Pete :pirate_flag:
I want to thank you for that link. Problem is I don’t get it. Many of the downloads just won’t open on the iPad or on my MacBook Air.
I have Kodi on my MacBook and it works fine.
I just don’t understand how to jailbreak the iPad or why the app from my MacBook just doesn’t transfer over to the iPad. Bummer!
Then it wont work on a ipad. jailbreaking ios isnt what it used to be, and its not the same as allowing unknown sources. Kodi supports mac os but not ios. So you might be out of luck unless you can figure out the jailbreaking procedure for ipad.
From what I’ve read and watched in videos numerous times Ipads and iphones are not cordcutter friendly . To be honest I didn’t even think it was possible to access developer options or install apps from unknown sources . Sorry I couldn’t be of help.
That’s quite alright, Pirate Pete! I appreciate the effort!
I don’t have an ipad or anything mac but from my research there are lots of articles about “jailbreaking” an ipad.
