More often than not, when I click to open KODI, it goes right back to my fire stick home screen. It doesn’t even open!! Also a lot of the links don’t work for me either on KODI
Make sure it’s installed properly.
Check this out follow it.
Clear your app data and try again. Make sure your resources are not being tied up. Uninstall unneeded apps and bloat ware.
Try completely unplugging the fire stick and wait 10 min. Check that ur internal memory is not full. Hope this helped!!
Will do thank you, fingers crossed
Thanks, fingers crossed that it works
