Good morning, My apologies if this is covered in another thread. I searched extensively and couldn’t find any information about my issue. I installed Nexus 20.1 (previously we had Matrix) and upgraded to 20.2 on our Android tv box. Since installing Nexus, we’re experiencing issues with glitching/freezing/stuttering then catching up/buffering (I’m not sure what to call it) during playback. This happens in every movie and tv show on The Crew and Seren, regardless of how low the file size or resolution quality. Does anyone know if there’s a fix or workaround? The only thing that we’ve found to stop it is to leave the playback control bar up at the bottom of the screen but that’s really annoying especially when trying to read subs. Thank you for your time and feedback!
I would go and update each addon manually. The addons might still be the matrix platform .
Good luck
Thank you PiratePete. May I ask how do I manually update the add ons? I have them marked to auto-update. Thanks for trying to help!
Go to settings, add-ons, my add-ons , then click on each addon one at a time , select “version” it will show what versions of the add-ons are available. Always select the one with the highest number. Good luck
