Kodi kicks out to firestick homescreen
Help!!!
Newly installed Kodi 20.2 Nexus Diggz 3.6 kicks out back to Firestick home screen every time it tries to load. I have uninstalled and reinstalled kicks out when trying to update PVR. How do I fix this if Kodi won’t even load???
Are you trying to load a full version of Kodi? If so what version of the firestick do you have? The older ones are lacking in space and it’s recommended that you just install one of Troy’s forks and just a couple of addons if so.
Clear cache n force stop after you do that go to another app and open another app and then go back to kodi also how many kodis apps do you have on your device I have a fork Kodi and they haven’t been working together too well
I’ve got a Firestick 4K Max. I’ve tried to uninstall/reinstall, Force stop, Clear Cache, and I even reset Firestick to Factory settings and reinstalled Kodi. All it does is tries to load but as soon as it starts to create PVR clients it kicks out to Firestick homescreen.
Any chance you can answer the questions I posted so we can have a better idea where to focus our answers or suggedtions?
Where r u get apk for Kodi n r you download it in the Android section because you can load they have different Cody’s for Windows Android Linux Apple a downloading it with the correct OS?
20.2 Nexus & Firestick 4K Max
Do you have a fork installed? That’s the way you can install two kodis on one device . Because I have troys 19.5 n Kodi 20.2 n kodi20 2 does the same thing. The only way to open it is delete cach n data but I have so much n put time in put it in I just left it n use 19.5 troy
