Kodi keeps shuttering . stopping and starting
Having trouble with my Kodi build . It’s the Xlite 702 build on a Nvidia Shield pro with a 1tg external hard drive . With everything set for top performance . Every time I watch a move I get shuttering " The movie keeps stoping an starting . I use RD links . I can’t locate the problem . Need some help . I am running the build on Troypoint 20.2 fork .
Sorry but I’ve never heard of that build. Could it be an old one, not designed for Kodi 20.1 or 2?
I don’t know .Their’s about 10 different builds in it . Before that I had Diggz build on it an it don’e the same thing .
Lots of new ones on troypoint. If you want something to play good just use one or two add-ons don’t use builds. Install one, if you don’t like it dump it, install a new one. Lots of choices
IMO Throttlejockey continues to give the best advise on watching tv/movies on kodi. Dump the builds and install individual add-ons. Kodi does not have to be complicated!
I did ! An it is still doing it with only one addon ( The Crew ) installed . Still shuttering . Stopping and starting .
I would always use real debrid with Kodi, not sure what else to tell you to try.
That’s what I always use .
Are you running Kodi through your external harddrive?
Try Stremio. I just use Kodi for a back up. Too many problems with Kodi. To be fair I’m using Onn and Firestick 4K Max. I’ve heard Kodi works great on shield though but I’m too cheap so don’t know.
I am running Kodi through a external had drive . For BWJ1 . Well you havn’t heard that from me as I use a Nvidia Shield . Can’t even get Pluto to load on the damm think .
Have you tried moving Kodi over to internal storage and see if it smooths things out? If not, maybe it is a faulty Shield?
Oh that is more than likely your problem.
