Kodi keeps crashing
I have downloaded the newest version of KODI and load DIGGZ and SUPERMAN and one more and when it loads and I try to watch something it comes back with a bunch of errors and shut’s KODI down
I get some crashing as well .
Depending on your streaming device, Fire Stick for example, two builds usually take up way too much space and will shut your stick down. So for low storage devices I wouldn’t run any builds on it. Just Kodi and one or two add-ons.
i agree builds on kodi can cause problems using to much space i just use stand alone apps and all work fine
Don’t use builds just put basic Kodi on and your favourite addons…
Builds are not a problem. Perhaps your device is. Ditch the stick for a cheap box with space and load all the Builds you want
builds on firesticks are a problem they dont have enough space an soon give trouble
stand alone add-ons, with a kodi skin if you dont like the default look.
