how to go about using kodi favourites on multi streaming boxes on sae network
Is there anywhere to get some spcific innstructions on this??
Not sure I understand your question. But to add a favourites you simply long press the enter button on item you want to save. A small context menu wii appear. Select save to favourites. Do the same to delete. If you want to see same favourites across all you devices you need a free service like Trakt. However Trakt has been unreliable for me lately.
Not sure I understand your question but are you looking for a way to synch KODI Favorites across multiple Boxes? If so I don’t believe that is possible. You would need a separate KODI Install on each Box and then you would add your favorites again if you wanted all your streaming devices to have the same favorites.
The only way to do that is streaming from a server.
Server includes movies, tv shows, apps, tools, save to favorite, and much more. The closet one can do that is Plex media server.
TP wrote an manual guide how to setup the plex media server and it’s very interesting guide.
Plex Media Server Setup Guide
