Kodi doesn't load
Watched Kodi last night, went to load it again tonight and a error msg popped up that said Seren had a error check log. So I rebooted it, and now it flashes and won’t load. What’s the deal?
Are you using a Firestick? If so, I’d recommend checking the available free memory on the device. Also, take a look at the cache for Kodi, and delete it (the cache, not the app) if it is too large. Both of these items can be addressed in “Manage Applications”.
Thanks. I’ll try both.
Sounds like you lost the scraper , go into your video add ons and hit update and see if it adds it back
Got it working, thanks…
