Tried to install crewnique 4x, 2 different 4k max firesticks. reset ea firestick back to factory. every time i get to “continue”, “build menu”, there is no “FRESH INSTALL” to click on. all 61 builds are there & i could click on ea individual one & con’t to let just the 1 install but i obvi want all 61 in the build to install! how come no one else has mentioned this problem??
All 61 what? You can only install one build. If you did a factory reset of Kodi then it doesn’t matter if you do a standard install. All a fresh install does is set everything back to stock Kodi before installing the build. What’s the problem?
I wish posters would proof read their messages before posting!!!
I had the same trouble. I just got a new Shield Pro, I was installing crew unique on Kodi. But when I was going through the steps the crew Wizard never indicated it was installed it would only indicate that was updated. And I would never get the build menu. So somehow and I cannot remember and I cannot tell anybody how I did it, I backtracked thru the system, found crew unique listed, I hit it, fresh install came up, I hit it, acted like it installed, I forced stopped Kodi then reopened it, and then the new skin came up and everything is working fine since then.
