I recently installed The Crew on a stable Kodi build on a Firestick 4K Max. However, when I attempt to reauthorize my RD account it indicates the code is invalid. I’ve entered the code a few times from different devices and got the same result. I had no problem re-authorizing FEN on the same build. Any suggestions would be greatly appreciated.
Make sure the letter o and zero are typed in correctly when you enter the code provide. Sometimes it hard to tell, so try them both if you are haing problems.
Man, isn’t that the truth!
Just some suggestions…Since my TV and my office computer are in two different rooms, I snap a photo of the code on my TV so that I don’t make any mistakes. Also, because the code times out, I set my keyboard to Caps Lock on.
Since you had no issues successfully setting up Fen, I’m certain that there really shouldn’t be any other issues.
