Kodi connect problem
I have follow Troys download instructions several times and still can not get my diggz repository to connect after installing from zip file. Have run the gambit. Cleared cache on T V,downloaded all movable apps to USB, reset and reloaded T V. Using https://diggz1.me/diggzrepo and will not connect when I get to Diggz Repository.HELP
You’re just using the TV as you’re streaming device I would suggest getting a fire stick or some other device probably doesn’t have enough storage or processing power.
Thank you
