Guy’s I am looking for some good Kodi Builds that has a TV guild built in to it ? I have the Doomzday Aspire Build and have installed IVUETV guide .The guide works but when I try to click on a channle to watch it redirects me to an addon page instead of the channel and half the time ivuetv don’t even work . Any ideas ?
I think there was one posted a month or two back. Skeleton? By @Jayhawks659 ??
Might get more info if you search within the forum.
Never got it to work on Shield devices for some reason. But the rest of the build works fine. The guide does work on Amazon devices. You can find the build in the crew wizard in the crew repository.
So for I found two builds with TV guides and EPGs . Phanomenal and Diggz Xenon . Just click on a channel in the epg an it gos to all the sources that offers the channel . Realy nice like having paid IPTV . If I find anymore I will post them .
… Scroll up. Skeleton Crew. In the crew repository. In the crew wizard.
Hi Jayhawks659 . I would like to try that build but I have a Nvidia Sheild PRO . Didn’t you say the TV guide in the Skeleton Grew build didn’t work in that box ? Did you fix that problem ?
so your saying the shield wont play nice with the shield??? after I made that pic for ya? WTH…
… well now which build to pick?..whichever one I get I will still call it Skeleton so I can use my pic
I’ll try it again. It’s built on mad titan.
I think IPTV within Mad Titan requires an addition resource to work. JET something or other? Don’t know if that effects anything in anyones ‘builds’. Although I think you probably aware of that, just wondering if it may be a factor.
That’s already setup. The IPTV works, it’s just the guide for some reason that won’t load. Even though the build is exactly the same, there is something about the Shield that won’t load the EPG in Kodi. Very strange. But maybe it’s just my device and no one else’s? Try it out and let me know.
I’ll give it a shot later today and plan on hooking skeleton up with emby for a test run.
Are you sure it’s not the new update keeping the guide from working with Sheild ? That update has caused many headaches .
I don’r get it but the picture looks nice .
He changed the icon for Kodi with the skeleton one he made.
Okay ! I don’t have it loaded yet but I will check it out .
Live TV section is no longer on my skeleton Crew build on my mecool km2. I figured maybe it was disabled but when I went into settings it’s not there at all as a menu option . Should I reinstall it ?
Honestly couldn’t tell you lol. I built it for others and then deleted the IPTV section on my own device because I use Tivimate lol
My test in on hold …I sent my server back to amazon and got another more beefed up, the I will set kodi companion app up with emby and see if I can work some magic
…or maybe it will play nice and be configured with magic out of the box ![]()
I think it’s now deleted everywhere lol
