What is the best Kodi build to get with Real debrid attached
@JokB
Hi. If you are looking to use builds, Diggz Xenon is good and stable. You won’t be disappointed. If you are wanting to use just add-ons, you can’t go wrong with Seren, Venom, The Crew, Oath. So it just depends on what you want to do and how you want to use your device. If you are looking to install Diggz here you go
Troypoint has lots of good tutorials on other builds as well, so might want to check those out as well.
Good Luck.
No build. Just my opinion. I’d rather install the individual add-ons I want and use partymode to auto launch the one I use the most frequently.
@Jayhawks659
I’m with ya. I have gone back and forth. Currently just have add-ons installed using real-debrid and everything runs flawlessly.
