Hi Fen is a great addon I did the latest build update and now when I try to find something with Fen it starts to search and then makes kodi freeze and I have to force close and restart anybody had the same problem
depends what device your using if its a firestick. builds will use up so much space and you get problems
Hi Im using nvidia shield, Fen has never done this after a build update before
only thing i can suggest is to go to source and download the updated build in one go
