Both paid and unpaid, Real Debrid and Premiumize streams in the following ADDons, not playing. Seren, Umbrella, Crew, and Fen lite. I have cleared the Cache and Force stopped. I am using an 4K ONN Pro That has been working fine. Diggz Xenon build
Just tried Umbrella, Fenlight and Crew and they all worked OK here.
Have the same problem, Installed Seren yesterday on Kodi. Debird and Premeonized was working okay yesterday. Today unable to get my movies to upload. Engines start but movie selections do not load up. Is this something with Google Ion?
Same thing today. Reauthorized real debird and preimmunized. Start engines start up and load up providers. As far as it goes. Returns to the movie list.
Umbrella and Fenlite AM been working flawlessly here for months on an ONN 4k Pro with Real Debrid
Well, none of those apps give free streams any more, but it sounds like you have something else going on with the paid sources.
I used Fenlight AM for several hours last night and it was perfect.
KODI Addons for the most part have always been free. You just need a debrid service (pennies/day) to get streams
Welcome to this awesome streaming group ![]()
just fired up Seren and it’s working fine here. Using version 3.0.67
Yes, the addons are free but the debrid service you need for these addons is not. Hence no free streams.
@PapaS Is the EF Hutton of Kodi. When PapaS talks…
Did you just update or download the Xenon build? If so, you may need to reauthorize your RD and Prem accounts. Each addon needs to be authorized separately i believe.
Just tested on my Xenon build and its working as well.
Yeah, just like everyone else has said, RD is working fine on all different apps on my machine.
Mike
Since it’s happening across multiple add-ons (Seren, Umbrella, Crew, Fen Lite), it’s probably not the add-ons themselves.
A few things to check:
- Re-authorize Real-Debrid and Premiumize in ResolveURL / URLResolver (they can silently expire)
- In each add-on, run Tools → Clear providers / Clear cache (not just Kodi cache)
- Check that RD/Premiumize is enabled inside each add-on’s settings
- Restart the ONN box after reauthorizing
Diggz Xenon builds sometimes push updates that break dependencies, so if this started suddenly, that’s likely the cause. Worst case, disabling the build and testing one add-on standalone will tell you quickly if it’s build-related.
What is happening is Umbrella, Seren, Crew will play one episode only. then it says check the log. the Log says Kodi is not playing videos. Fen Light is the only addon that will play more than one. otherwise I have to go to settings, Apps, Kodi, then clear Cache and do a restart. Then same thing happens again.
