hello people …
recently i instead of restart firestick reset it so i am downloading apks and one question comes to mind should i install kodi addons or build?
as always your responses are appreciated …
thanks …
still … STAY SAFE …
hello people …
thanks …
still … STAY SAFE …
Kodi with 1 or 2 add ons for fire stick at the most. Kodi with Seren and Real Debrid hard to beat.
then that is what i will do …
thanks …
Im currently running xlite build from 709 wizard on a firestick 4k max and it runs really well. It’s setup for movies and tv shows.
It’s super easy to setup real debrid on all the addons at once with the 709 debrid manager tool.
I suggest a build for starters
I built skeleton crew to be light and easy using real debrid and Trakt.
This has been discussed at lenght i suggest the search.
Firestick? No build addons. You can get everything with one addon and real debrid.
The new Kodi build doesn’t need Real Debrid and it works great. I use Trakt and it has all the shows I watch. That way it’s easy to go to the show I want to watch.
the way i went is all stand alone apps less problems
