Loaded Kodi with Crewnique build on my laptop (Win 11) a few weeks ago and everything worked fine. Then, I had a windows update and the normal addon updates and started getting Crew errors. Everytime I try to run a movie or show, I get instant and constant buffering. Tried other addons and get the same problem.
Any advice?
I’m not sure I can tell you why it is happening, but feels like you may need to uninstall/reinstall Kodi and the addons. I’m not terribly versed in backing up Kodi for reinstall, but since it is windows maybe you can use a USB flash drive. I’m sure there are others here that have done it successfully.
I have Kodi on my laptop Win 11, I put the apps on manually without any build and it works perfectly even after updates from Windows, for movies I prefer Promise, Magic dragon, Asgard, Homelander…
