Kodi addon for maintenance
I read the latest Troypoint guide for addons and ran across one that dealt with the maintenance aspect of Kodi like adjusting the cache and other tools, but can’t remember what it was called. Any help would be appreciated
It might not be the one you read about, but the best cleaner with the most options is called KCleaner.
Thanks, but thats not it. This was specifically a Kodi addon.
I have it on my Kodi…works awesome…if I find it…will let you know
Found it on troypoint site
do a search…put in Kodi Maintenance
Hey guys,
This might be what you are looking for: How to Install & Use EZ Maintenance+ Kodi Addon
KCleaner is specifically a Kodi addon. Doesn’t work on anything else. That’s what the K in KCleaner stands for (Kodi)
But I guess it’s more for advanced users, might be why you haven’t heard about it.
or you could use EZ maintenance
The crew wizard might be what you’re looking for with the cache settings. :slightly_smiling_face:
Thanks for these suggestions. Is there a difference between EZ maintenance and Open Wizard? And I can’t find K cleaner which seems like another good option. I’m running Kodi 20.3
Cleaner adons do pretty much the same thing. Open wizard has some preset configs tools to help Kodi run on say a device with limited RAM. It was what I used on the Max sticks when I use to use Kodi. The adon has been around for a while now.
Thanks Miki. I guess you can’t go wrong with any maintenance addon.
I used it on the 4 K Max as the preset for low Ram devices helped a lot to make my streaming more stable in Kodi, and I loved the cache clearing on startup.
The app you want is.
EZ Maintenance
Here’s the URL – https://peno64.github.io/repository.peno64
Thanks.
