KODI 21 Omega launch screen Frozen
I’m using KODI 21 Omega on an Onn 4k Pro and is the first time I’ve encountered KODI launch screen freezing up. Have cleared cache, my Onn device and restarted without any results.
This happened frequently with my Fire cube and I had to delete a file in order for it to launch, but it’s been over a year since I’ve seen this happen and can’t recall the file.
I have search Troypoint and cannot find the original source on KODI Frozen Launch Screen.
Any help would be highly appreciated.
Thank You
Jeffrey
Have you tried force closing Kodi and clearing cache?
I have removed the Kodi splash screen from startup by creating a advancedsettings.xml file and add
< splash >false< /splash > to it.
Then add the file to Kodi data folder.
Usually a hard restart of my ONN box clears any startup issues I have with KODI. But I wouldn’t spend a whole lot of time trying to fix. The beauty of having Troy’s Toolbox is it’s incredibly easy to download a fresh copy of 21 with Downloader then just reinstall whatever Build/Addons you use. Reauthorize RD + Trakt (if you use it) and go. Everything should be good to go again
Had Tried Everything.
Did a hard restart, cleaned both KODi and the Onn Pro device.
Nothing.
The splash screen was stuck like a Tractor at a Mississippi Tractor Pull.
