Is anybody using kodi-20-nexus yet? I am reluctant to updated from 19.4 as itโs still working ok So I was just wondering if anybody has done it? Thanks
On pc, but i wouldnt update and use it, its in beta and you can expect issues with builds/addons. Id wait for a stable build and for people to update their repos to 20. But you could try it on a separate download if you want.
Thanks for that I was just keep using 19.4 then until I see other people using the new update
Yea, no problem. Im sure people are using it but i dont think its effect yet for major use. Kodi updates alot. I have seen it go from xmbmc to all stages of current kodi. lol
Iโm using Mavenโs Nexus fork on Kodi Nerds and it works great with the crew.
I have a load of add-ons on kodi 19.4 which are working fine so Iโm not going to mess about for the time being
Excellent advice@Wardylfc20 ! If it ainโt broke donโt fix it
