hi mate
yes i am at mom back on 18-9 but am aware that a lot only work on 19-4 hence the reason for wanting to go to 19-4. the particular addon i was having probs on was ok for both and of course it actually ran for few mins before freezing.
cheers
hello
thanks for that heads up, a favour i would ask, if you have oath addon search tv programs for shooter and run an episode. this would show me that yr vpn does something mine cant.
i would appreciate that very much. i assume your pc is on windows 10.
cheers
I can do that 4 U.
Where R U located ?
I am in Canada .
What am I looking for ?
Pm for shows and movies for kodi and such apps please.
hi
well if u have kodi 19-4 and you have the oath addon go tv shows then search, type in shooter its a old tv series. go first series then go first episode. you will then watching the very same thing im having trouble with.
thanks for help
I have 19.4 on firesticks and windows 11 laptop, all with Surfshark vpn working brilliant…
thanks for that are you in uk and maybe windows 11 may be different but thanks for your attention anyway,
cheers
Yes UK, the vpn definitely makes a difference on the Sport streams and iptv.
