Could you please put Kody 19.3 back Into the rapid app installer because 19.4 won’t play any of my favorites
What device are you using? What addons or builds? I have been using 19.4 since it came out with no problems.
NVIDIA Shield Pro. I suspect that Oath hasn’t been updated to work properly with 19.4 because Saran favorites work fine
As its not a major update virtually all addons should work just fine.
I havent used oath in a long time but as i recall you save to your favorites the same way you do in seren. I have used 19.4 without issues to saving. You could try uninstall and reinstall to clear and bugs.
THANK YOU!!! I thought that would be a good, Just In Case precaution.
Troy, your fork uses 19.0 and I get the notice that I should update to 19.3. Any chance you will update your fork? Thanks
