Troy.
We are trying to reinstall Kodi 18.9. We are using Troy point Installer and the download seems fine. The installer Says '“App not installed. The package seems corrupt”. We have tried several times over the past few days with the same result. We have Kodi 19 installed but iti s not ready for prime time. Any suggestion?
Hello @gnx035 that error usually indicates that the application is already installed. I know it sounds stupid but that is usually what it is. Try going to the page that shows ALL apps on your device and more than likel you will find it in your list.
