Have the KM7… Wonderful box… Have it set up and running, BUT … unable to control volume or power box on or off… Looked at reviews for the box and searched for help… Are there settings that i can go to and set ?
Im hoping a RESET is not my option… A Hard reset that is.
Thanks for any help in this matter
look into cec settings
Pete
Saw no option in there for the remote.
Go into Android settings , then devi e preferences, then advanced options. Look for HDMI CEC…Good luck
Pete
