Yes, I am in the US I have BBCIplayer working on my firestick through my VPN but cannot it to open on my Kinhank GI not sure if that’s because of Google…
I would try different server locations in the UK.
just looked at specs seems very interesting price in uk around 100 pounds
Similar specs to KM2 plus deluxe except only 100mg ethernet as against 1000mg for KM.
Except KM is 30% higher in price
Yes but if you buy from Mecool direct you get a 15% discount so maybe 15% in that case. It depends if you need the 1000mg ethernet or not.
What I like most about the Kinhank 4+32 is that it’s competition. I hope 5 more similar units come out soon! Competition is a good thing. Ok, the Kinhank is only 15-30% cheaper, but I like the direction of price with added features from earlier devices. That keeps MeCool and others watching price while adding value!
Some ppl are going nuts over the RockTek G2 box as well. $150 cheap china box that is marked up extremely high. Specd similar as the device being mentioned in thread
WOW, ya got me! There is also always a small line waiting to jump off the roof, but overall competition tends to raise quality and reduce prices, IMO
I recently received the G1 and have been using it exclusively for a week. I am very impressed. Smooth, fast and so fer, absolutely no buffering. Loaded Kodi and an iptv and everything in working flawlessly. I am new to this site and naught quite sure what I can and cannot say. Nuff for now.
Not Much!
This is my first post as a Patron! The Kinhank Gi android box is a great android streaming box as I stated in an earlier post but, I have since discovered for some reason some “channels are not avaiable on this device” as it states when I attempted to add certain channels to my favorites. Has anyone experienced this with this or any other devices?
Never heard of that and Googled it and from what I can see this is just a certified Android streaming box. When you say there are channels missing you mean Apps right? If so have you looked in the Google play store to see what Apps you want?
I did a search for several channels and received the "this channel is not available on this device " for each one. I’m not sure if I am allowed to identify the channels. I have added these same channels to my favorites on a different android device.
Again not sure what you are trying to do. Are you looking to add Apps, or KODI Addons? Or are you talking about adding channels on your IPTV service to your favorites? If you are using Tivimate it’s very easy. Just open the menu and add to favorites.
Yes, I am trying to add to my favorites in tivimate. But. My Kinhank G1 won’t allow certain channels. I may try different locations on my vpn.
Yes, I trying to add to my favorites in tivimate. When doing a search in tivimate the channel is not available yet it is available in my other android device when doing a tivimate search. By the way, I am using the same iptv service on both devices. So I conclude that Kinhank is not allowing certain sites if that is the correct reference. I do a channel search on tivimate when I receive the "not available " message.
Just to clear things up, when I search in tivimate for the “channel” it results in “not found”. When I search in playstore I get the message " not compatible with this device". I hope that helps explain what I am trying to say. Yet, no problem adding to my favorites when using my other android device. Not a firestick.
Searching in TiViMate has nothing to do with a VPN. The channels are contained within the playlist added by you or lists that you add. Tivimate is strictly an IPTV player and does not contain any content until you add your Subscription IPTV or free M3Us or M3U8 playlists. Adding favorites or groups is done by you from within Tivimate, using the playlists you have added. I suggest you use the site search function and read the information you can find about Tivimate. In order to use TiViMate properly you will need to purchase a premium subscription to the app by using the “Companion” app from the playstore. Your posts are very confusing and it’s difficult to understand exactly what you are trying to do.
