ITTechBasics IPTV
I’m stumped. Hopefully someone can help.
Thanks. So am I.
I finally got the playlist to install. I rebooted the modem and router and it worked.
Yippee.
Hadn’t thought of that one! My devices are connected via LAN cable. I’ll have to try that sometime. Thx.
Why did Troypoint.com have pricing starting at less than $9/month?
Because that review was done before they raised prices.
Thank you
Have you communicated with them on WhatsApp?
No. I’ve just moved on to another service.
I’m a little confused. Are you still using ittech?
He left ITT for another service
So did I
I have followed you pretty closely sim_bill because I trust your abilities and opinions. I currently us ITTech because you recommended them a couple years ago and they have been great. May I ask what you use now? I ask because if ITTech is getting squirrely, I want a solid service for football season. Thank you in advance.
Try a PM to Miki. He may have some options.
Hi! I installed the onn 4k pro last night. It’s working like champ. No issues so far. ITTECHBASICS has not responded since Tuesday the 25th 5:38. It is at a point that my replies aren’t being submitted. When I try it goes automatically to the login page. It’s a shame because they used to be very reliable.
Thank you for your help. Happy Thanksgiving.
I have this same service. They movies and shows are grainy. They take forever to respond. Lots of buffering. Im using smarters on the Onn TV box. Is there any alternatives besides Apollo.
I saw this message posted recently on their Telegram channel. When I cut and paste it, it converts the web address in the message so I will break it up so you can see what it is.
Email providers continue to block our emails and invoices from getting to you. Make sure you check your client portal account for invoices and ticket replies.
“https://”
“ittechbasics”
“.com”
“/whmcs/clientarea.php”
Just string together the parts of the address without the quotes.
I hope that helps.
Other than the useless NHL group where the links never work, I continue to have a great experience with them. I found a site that tells me the home channel for each NHL team so I can manually hunt down the games I want to watch.
I gave up on ITTechBasics about a year ago as the customer service has deteriorated and the quality has also gone downhill. You may want to PM Miki as he can probably recommend a better service.
Thanks for the vote of confidence @sim_bill but I no longer give recommendations or suggestions for unverified IPTV services. Way to many variables these days.
Yeah, that rabbit hole filled up with quicksand quick enough :grimacing:
