ITTechBasics IPTV
Yes that’s right but I was able to remove the bouquets to only have North America selected. Also saves about 50,000 movies from having to load
Absolutely. If the service at your request will cut down the streaming channels, movies and series for you from other countries you don’t want, it takes much less time to load. ITTech is one who will do that. I get a chuckle out of those who rave about all the free channels on GitHub, then complain about how long it takes to update, load and then buffer.
I would like the option to bouquet even individual channels. There are soooo many duplicates that are just taking up space.
In a perfect world…
I’m having a hard time getting my ITTECH IPTV login details recognized by Tivimate. Does anyone have the affirmative URL from ITTECH IPTV that Tivimate will recognize?
http://tvtube-iptv.com:25461
Bill do you use Tivimate? Even with the URL you helped me with I still get an error message in Tivimate and I’m still unable to merge with ITTECH IPTV.
That is the url address I have. Use it for the Xtream codes option on TiViMate along with your sign in and password. If that doesn’t work, contact support@ittechbasics.com They’ll advise you accordingly.
Do you use Tivimate? I’ll give it another try. Thank you!
I do. It works perfectly with this service.
Ittechbasics IPTV uses the same billing formt as xtreme hd. I’m not saying they’re connected I’m just saying they use the same billing format. As I’ve never used ittechbasics yet. Maybe next though.
ITTechBasics IPTV has been consistent for me. However I haven’t been able to get it to work with Tivimate. If anyone has found a way to make these two work together let me know please.
What does it do when you put it into Tivimate? What player does it work with? Are you using Xtream Codes or the m3u file?
Use Xtream codes. Type in the url address.
Can someone tell me the difference between an M3u playlist and an M3u PLUS playlist? is the Plus one better? I searched this but couldn’t find anything to help answer this.
Much appreciated.
I think you must mean m3u or m3u8
m3u is just the playlist and you must add an extra url to get the .xml file for the EPG.
m3u8 has the epg .xml file integrated in it.
ITTechBasics used to be buffer free for my setup. Not anymore! Most likely server side issues. (Too many users hammering their servers) Tried many services on Troy’s list and most of them are fine during the day, but buffer towards the evening time, even with a good VPN. such as Proton or Surfshark.
That kemo lemo ky service is so oversold. Everybody and their bother reselling it.
Hence the buffering! Yep always on the lookout for a stable service.
ITTechBasics is still buffer free for me. I probably should disclose I use a direct CAT6 LAN cable connection for my internet to tv box and not wi-fi, which can make a difference. From time to time I’ll also change servers on my VPN if a feed gets sluggish. That will do the trick every time. Because of the nature of IPTV, it is very difficult to get 100% no buffering for any service.
