Italian audio on Stremio?
Recently (I’ve made no changes to my system) Stremio is returning mostly streams with Italian audio (“ITA-ENG” on the stream summary).
Is it just me or is there something going on here???
@sktn77a
If you go to audio trakt you should be able to change it to english if its available.
Thanks TP-Dracoo. When you say audio trakt do you mean my Trakt account or the actual stream audio track? If the latter, how? I looked over all the settings and can’t find anything.
@sktn77a
Audio track, typo from typing trakt alot. Look for the music symbol, english should be jn there if its available.
I dont have this issue unless looking for something like english dub.
Got it. I found the “Dub” icon on my Windows PC install and switched over from Italian to English. I’ll check the firestick when I get home tonight.
As the settings and addons are on the server and not your device, your changes made on one install will apply to all your installs and every device. For example, if I save a movie to my favorites that movie will show on all the devices you have Stremio installed on and logged into.
Thanks. I just wasn’t sure if that setting was only for that particular movie I was watching (The Batman) or if it was an app setting.
