I described in a previous post how I intended to get a Mecool KM7 because I had grown frustrated with the work-arounds necessary to compensate for lack of Firestick storage.
It has now arrived after a couple of weeks and I have been setting it up with some problems.
As a U.K. resident being able to use the apps for the major U.K. tv channels is very important not just for live tv but for their extensive catch-up content. These apps are BBC iPlayer, ITV Hub, All4 and My5 and are all available to stream for free. These are the problems I have experienced:
- No BBC iPlayer or All4 apps in the Play Store. I found the BBC one elsewhere and it works fine. I have yet to find an All4 app that will load, or does not immediately exit if it does.
- ITV Hub is in the Play Store and installs ok. But when loaded a message appears that says that the producer has not purchased the rights to use it on this equipment. I can find no way round this.
- Only the My5 app is in the Store and works correctly.
I don’t know if anyone else has had these problems which renders this box useless for me unless they can be overcome (I am not holding my breath).
Which is a pity because I otherwise like the unit. It is noticeably quicker at downloading and installing apps than my Firestick 4K and has streamed from Crewe, Stremio and Cinema with Real-debrid flawlessly, and not having to mess about with shuffling apps on to extra storage is a boon.
I saw in Troy’s review of a Mecool box that he warned about the absence of Netflix rights. Unless there is a way round the issues I have raised then perhaps a similar warning should be given about mounting these U.K. based tv apps on it.
Incidentally I found another oddity which I cannot explain. I downloaded apks to the download folder. Neither Xplorer nor MiXplorer (from techdoctoruk) showed these files but ES file explorer did - weird?
I had thought about getting a Nvidia Shield but if the same issues apply it would have been a more expensive mistake - does anyone have experience of running these apps on one?
I think my best bet will be the new Fire TV cube - not as much store as the Mecool and more limited connectivity but affordable - but the U.K. Amazon store is out of stock!
