Issue With UK Turks
I have the latest version of this app installed on my firestick, but for days I’ve been trying to access the Catch Up TV section and nothing is coming up. Am I the only one with this problem or is it a problem with the app?
You are probably better off using a vod style app to watch your shows and movies. Works way better then any catch up… also thats a free app so stuff comes and goes.
Or go with a provider
latest version is 1.1 0 catch up working ok
I have that version which I downloaded from the official website but it still doesn’t work.
strange i downloaded from unlinked an its working fine try deleting it and reinstall
unlinked code 67664537
I played around with the app and found out that the Catch Up TV section does not work when the VPN is on. I turned off the VPN and then it worked perfectly. :roll_eyes:
