I searcged on APKpure for Just Player and nothing. First app that showed was NOVA player.
Thanks Dracoo, Geez sometimes I am stupid. Searched in APP store and it takes me to YOUTUBE with comment …"Press SELECT to search in this app. @Steve24 found it in APKpure. I could not find it in there either. In APKpure, after searching Just Player, it displayed Nova player. Anyway…no worries I give up just letting you know. Only place was Google play store but it will not let me download to PC. But thanks again.
Is anybody have issues using MX Player in Syncler? Syncler plays fine with it own player, but the MX Player freezes. I perfure to use MX Player when ever I can. Just don’t understand why it is not compatible with Syncler. Any suggestions would be appreciated.
Check the settings in mx player, and ensure you have all audio codecs checked.
Make sure that HW is also enabled.
The video plays now but still can not get the sound to work.
Settings> audio and make sure audio player is enabled.
Then settings>decoder. Make sure the first 4 HW decoders are enabled.
Scroll down to HW+ audio codecs and
make sure that AC, AC3 and EAC3 are enabled.
If that didnt work, go back into mx settings and HW+ audio codecs and enable them all.
That way your device and the stream you are selecting, will pick up the correct audio codec that the stream is using.
Ok. I dont normally use MX player, as i find Exo player good enough.
I have just tried three different series and some streams dont have sound, whilst others do.
So, if you have made the settings changes, i recommended, perhaps try different streams until one plays with sound.
I cannot offer an explanation as to why Syncler does this. I tried on both Stable and Beta version.
Perhaps an email to the dev, might produce an answer.
developer(at)syncler.net
Good luck
I’ve never had any trouble with Syncler and still aren’t really, just one thing that has suddenly started happening, firstly I have Syncler on 4 TV’s, 2 Sony and 2 TCL and use vimu player both Syncler and IPTV, the problem is that on 2 of the TV’s when I press the play with button a white screen appears and I have to choose Vimu manually but on the order 2 TV’s (1 Sony, 1 TCL) it just uses Vimu automatically and plays, I’ve tried resetting the app, been through all the settings to make sure everything is matching but still the same, any ideas?, ta Gareth.
