Is anyone having problems IPTV Smarters?
Morning, Hap, Have you gotten this resolved? My sub just expired and I have not been able to renew nor can I get any response from customer service. Thanks, Scott
I’ve always had problems with smarters. Can’t seem to get anyone that can help with the problem. So I don’t use Smarters Anymore. If you find an email to the owners, they won’t respond. There are no updates available that I can find either. Through some of the responses I’ve seen on Troy point, I did get it to work the best that ever has. But alas, it got to the point where nothing worked the way it was supposed to.
So you have attempted to contact them through their site but don’t get a response?
Yes. I finally gave up on it. The only reason I kept trying was because in the beginning, it worked very well. Seems Like those days and weeks went by And it got worse and worse. The last time I used it it was pretty much useless.
This is the topic ive found closest to my question. Trying to download a player for my galaxy android phone? I cant download Smarters as its not showing up? Any idea of a player that works for Android phones? Samsung Galaxy to be exact.
Did you try the download link from the Troypoint Toolbox? IPTV Smarters Pro 3.1.5.1 → https://files.catbox.moe/08yg78.apk If that doesn’t work you could try Televizo, which is the player I prefer for phones. https://play.google.com/store/apps/details?id=com.ottplay.ottplay&hl=en_US
Thanks i got Smarters through the link you sent. However, now im curious why do you personally prefer Televizio over Smarters? Wondering if i should get that instead?
It’s just a personal preference. Some like Televizo, some don’t. I feel like it’s quicker in response and less quirky. I’m using the premium version (modded) 1.9.3.21. You can try both players and see what you think. I had both on my phone at one time.
I’m having the same problem for some reason, Downloader is not letting me download IPTV Smarters. ERR_CONNECTION_REFUSED ?
I’ve tried Troypoints tool box link (code 250931)
I’ve tried the IPTV Smarters code 164547
Any idea what I’m doing wrong.
I did delete the Downloader cache as well.
Any ideas?
what device? Try rebooting everything, you can try 741278 for Smarters.
Thank You, that CODE worked perfect. Thanks again.
You’re welcome, glad I could help. :v:
tried iptv smarters several times , can’t get it to work …. I deleted the app three times and started over. I loaded TV tap and put in M3 u no problem.
