Any ideas why my IPVanish keeps disconnecting?
What are your settings and what box are you using? I’ve had no problems. If you did any updates, then you need to redo your load settings. They revert back to default.
I’ve had this issue for months when using Stremio with IPVanish. I had dozens of conversations and sent countless test logs to the IPV help/support but never had any success. I have since cancelled my subscription to IPV and switched to ExpressVPN and no more disconnects. I use vpn safety dot to keep track of my connection. Of note, I tested all protocols udp tcp ike2 and wireguard as well as location cities and countries, without success.
I use a fire stick 4K. I never had any issues before. I now use Hypersonic IPTV. Reinstalled it today using the beta format. Tried all the protocols with no luck. Frustrating!!
