IPVanish Safety Dot(Gray)
I installed Troy’s latest version of the “safety dot” while using ipvanish vpn. It is much appreciated. The grey-like feature is almost invisible if you’re not watching. I would recommend this to ipvanish customers if their device isnt offering the cut-off feature. Thanks again to Troy and company for all you do. Continue to stay safe.
Using the VPN Safety Dot. You can change the icon to whatever you wish. You just need to convert whatever logo, picture, or even a self-made pic into an icon. Then just follow the instructions for the custom branding. I change their icon into a SS logo I custom made icon using editing apps on my laptop.
Here are the two sites I used to do this, but you can choose any icon converter site you want, but you have to use the Branding website to complete the process.
Have fun…
Online ICO converter
VPNSafetyDot Custom Branding Configurator
I did this with SS. So not certain about IPV, but it should work for it too.
SURFSHARK
