here is something that happen to me and I don’t know how it happen.I logon to my computer and I couldn’t get on to my internet.I check to see what went worng.My router A7 tp-link router shows it as my internet access but could not get onto the internet.but when I connect my IPVanish I get internet service,should it be my modem that connect me to the internet,I have my router connected to the tv.how can I correct it problem
Check the Settings in Router and PC for connection only trough VPN if you find it deselect.
Do you have an active kill switch? Maybe a short disconnect and IPV locked you out as that’s what a kill switch does, then clicking on IPV may have cleared the lockout as it found a viable connection and removed the kill switch. Only a guess.
