IpVanish not working with Yeahiptv
New to this forum so I hope someone is familiar with the problem.
I recently subscribed to Yeahiptv and stream it using Tivimate. Works great until I turn on ipVanish vpn. Prior to Tivimate, I used JCMedia and Sportztv.
Any clue on changes If I need to make changes in settings or something?
Try changing the VPN protocol and see if it makes a difference.
You need to tell them that you’re using a VPN and they can fix it for you.
Thanks I do have an inquiry sent to them.
Thanks everyone. I reached out to Yeahiptv.vip and they turned on VPN capability.
