I’m using the newest version of ipvanish on my android box running android 7.0 . But the buttons don’t work after it’s installed. I had an older version before this and it worked. It was before the new format . Weird thing is it works on my other box that’s on WiFi but for the one hardwired it doesn’t . I been looking for a version compatible but can’t find any .
Ipvanish has two separate app versions (v4 and v3)
If you want to find different versions of the more modern version (V4) than I would suggest using aptoide. If you search for the app on this store, you can find multiple versions of the app there, I think I see about ten older versions dating all the way back to December of last year.
If you need V3, which is a much older version of the app, but still necessary for some older devices, then you probably will have to sideload it using the Downloader app. After searching through the IPVanish website I found an article that has a download link for this version of the app.
Here is the article I found that goes about sideloading the app
It gives links to both V4 and V3 versions of the app. Choose whichever one you prefer.
Great thanks . Found a legacy version that worked but wireguard is t in the list but I guess as long as it works . Don’t get why it works on one box and not the other .the latest version I mean.
